Secrete pentru Siemens
1 836 vizualizări
62 răspunsuri
Linkuri topic "Secrete pentru Siemens"
6998 mesaje
din 05/06/2005
SIE-A60
Va rog,scrieti aici cat mai multe secrete,coduri si smecherii pentru telefoanele Siemens.
2012 mesaje
23 iunie 2005, 23:27:29
uite cam ce am gasit pt siemens, adevarul este ca nu am cautat prea mult....
Siemens S1 / S3
Tetris: Power on phone and enter PIN. before phone has locked onto network, F9, send own number, hit right button, hit 9. left is 2, right is 8, rotate is 5, and drop is 4.
Monitor Mode: Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, HangUp Button (Red HandSet key)
Now "Monitor" should appear at the bottom of the Network Options menu.
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators:
* = only available when call in progress )
CHChannel Number
RXSignal Strength (dB)
NNCC (Color Code)
BBCC (Color Code)
CICell ID (in Hex)
C1+how long before phone does forced hand over.
(see RX and RXAM)
LAILocation Area Identity.
Display Network ID code (42F010 = 240.01)
and MSC
TXPWRTransmit Power (dB)
RXAMReeceive signal strength cut-off point
TS*Time Slot Number
TA*Timing Advance. Distance from tower in Km X 2
PL*Power Level
Siemens S1 / S3
CHChannel Number
NNCC (Color Code)
BBCC (Color Code)
CICell ID (in Hex)
(see RX and RXAM)
and MSC
TS*Time Slot Number
PL*Power Level
2551 mesaje
din 27/07/2005
31 aprecieri
sysop:)
1531 mesaje
din 25/06/2005
12 aprecieri
SIE-MC60
pentru browserul telefonului
scrieti la "go to" fara http:// internal:settings
SonyEricssonT630
Why/what?
28 mesaje
din 16/08/2005
SIE-MC60
PT a downloda fisiere mari ex 510 kb scrii un sms cu adr completa salvezi mergi la acel sms il accesezi selectezi adr si apesi tasta de apelare. ps: sa scrieti si http:// la inceput ex http://adqwap.com
Adaugat de DSF: verifica si topicul Siemens: Link-uri wapix.
MBa
28 mesaje
din 16/08/2005
SIE-MC60
xHTML pe siemens mc60? Cum? Simplu la home page scrieti http://wap.orange.ro/index.xhtml si gata puteti accesa pag xhtml. Vedeti? am modificat mesajul.
MBa
28 mesaje
din 16/08/2005
SIE-MC60edgetwism 06-08-2005 18:34:25
pentru browserul telefonului scrieti la "go to" fara http:// internal:settings
MBa
sysop:)
1531 mesaje
din 25/06/2005
12 aprecieri
SIE-MC60
cu internal:settings setezi browserul telefonului!
1046 mesaje
din 18/07/2005
12 aprecieri
SIE-C60
nu pot downloada melodii midi mai mari de 70kb prin metoda eta imi spune'nu poate fi procesat'de ce?
28 mesaje
din 16/08/2005
SIE-MC60Termo 25-08-2005 19:41:30
MBa
sysop:)
1531 mesaje
din 25/06/2005
12 aprecieri
SIE-MC60
si amr-uri pot fi luate de pe net cu ETA...imi merg cele mai mici,dar am incercat cu un amr de 300kb si nu a mers!
28 mesaje
din 16/08/2005
SIE-MC60
Atunci nu stiu.
Eu pot sa iau si fisiere de 2 mb. Ai efectuat corect setarile java?
MBa
sysop:)
1531 mesaje
din 25/06/2005
12 aprecieri
SIE-MC60
la mine setarile java sunt corecte(asa cred)!
*alt cod pentru siemens *#9999# ATENTIE RESETEAZA BROWSERUL TELEFONULUI!
1046 mesaje
din 18/07/2005
12 aprecieri
SIE-C60
eu amr nu iau,fiindca nu le pot pune ca ton de apel
Înapoi la Trucuri și sfaturi
