GarminXT pe Omnia
11 149 vizualizări
181 răspunsuri
mikem1
79 mesaje
din 27/02/2009
15 martie 2009, 09:25:07 • actualizat 16 martie 2009, 08:54:52 (4 ori)
Salut
Am deschis acest topic deoarece nu am gasit aici nimic legat de Garmin. Tocmai am instalat pe tel. meu GArminXT cu ROAD2008 si este mult peste IGO8. (detalii harta, conectare GPS).
Daca va intereseaza, mai jos sunt cateva indicatii pt. instalare pe care le-am gasit pe net si le-am modificat putin.
Download GarminXT : http://www.netdrive.ws/155823.html
Download Mapsource ROAD2008 Romania : http://www.netdrive.ws/147867.html
OMNIA INSTALL (and probably many other win mobile devices):
Unrar GarminXT_omnia.rar
Garmin mobile XT:
1. Connect device with PC (Active sync for XP, and Windows Mobile Device Centar for Vista).
2. Start "GarminMobileXTforWindowsMobile_50020w" on your PC (install in storage).
3. Start "GarminMobileXTFreeBasemap_4xxxx" on your PC (install in storage).
4. Start "GarminMobileXTSupportFiles_4xxxx" on your PC (install in storage).
5. Run GarminMobileXT on your mobile and click “Connect to a Garmin GPS" go to ’setting > about’ record the Card ID
6. Open "Garmin_kgen_15.exe" and enter Card ID that you find it, never mind it says ("Enter your Unit ID here:" ) to make ("Generate") key ("Your software unlock code:") for garmin mobile xt ("Select software product").
7. Copy the generated key in sw.unl (erase "copy the key here!!").
7. Put the sw.unl in Garmin folder in your storage.
Now garmin xt is unlocked.
Maps:
Install MapSource on your PC. Unlock the map using step 2. Generate the map for Romania and transfer it to Omnia.
1. Put any map that you have in Garmin folder in your storage.
2. Again enter your Card ID that you'll find in Settings -> About (not Unit ID, never mind it says "Enter your Unit ID here:" ) to make ("Generate") key ("Your map unlock code:"). This time you are using lower generate key, so all that is left before generating key is you need to select map product ("Select map product:") or enter MapID yourself ( if the mapset is not on the list, then choose "<custom mapset>").
For Romanian Road2008 the MapID is 1189
3. Copy the generated key in gmapsupp.unl (erase "copy your map unlock code here!!!").
4. Put the gmapsupp.unl in Gamin folder in your storage.
Now the map is unlocked too.
Enjoy!
tzec_u
18 mesaje
din 03/03/2009
15 martie 2009, 18:29:53
multumim..eu personal chiar aveam nevoie cu igo8 nu prea ma descurc..pana acum am avut doar nokia si am folosit garminul pe ele....o sa il incerc si eu
unOHM
122 mesaje
din 15/03/2009
19 martie 2009, 22:34:25 • actualizat 19 martie 2009, 23:06:52 (2 ori)
Este cu f multe clase GARMIN peste IGO8. eu folosind Garmin pe Nokia :coolup: De cateva zile am instalat IGO8 pe Omnia, dar nu ma multumeste deloc :wallbesh:
Totusi as dori sa va intreb daca este full screen acest Garmin(am citit pe niste forumuri ca NU ar fi)daca functioneaza atat portrait cat si landscape (de ex IGO f-tioneaza numai portrait full screen), si , totodata as dori un binevoitor sa ma ajute si pe mine sa instalez Garmin (posed acest telefon de f putin timp pt a ma descurca cu el asa cum trebuie)
Multumesc anticipat de ajutor si RESPECT celor care se zbat sa ne ajute
adyy35
95 mesaje
din 05/03/2009
20 martie 2009, 00:53:01
salutare
deci aceeasi problema
ma descurc in prima parte
dar de unde incepe cu maps nu inteleg nimik
daca poate initiatorul
sa zica in romaneste
cum se face exact
ar fi super....
mersi anticipat...
e pacat
sa nu il folosim si noi
maja_ro
566 mesaje
din 24/02/2009
20 martie 2009, 16:56:13
daca l-ai instalat pe omnia si merge de ce nu ne spui in romaneste pas cu pas cum ai facut?
bobocul
27 mesaje
din 15/01/2009
20 martie 2009, 18:09:04
Eu nu reusesc sa pun hartile.In Mapsource cand ii dau sa-mi mute harta zice ceva de acces blocat
Arrow
9475 mesaje
din 30/07/2005
20 martie 2009, 18:41:41
nu folosi mapsource.Pune hartiile in folderul Garmin pe card sau unde e instalat.Ma gandesc ca nu difera de un Htc.Eu pe m3000 cat si pe Diamond nu a m folosit nici un mapsource
unOHM
122 mesaje
din 15/03/2009
20 martie 2009, 19:07:48
dar e asa greu sa spuna cineva PAS cu PAS in limba romana ce e de facut pentru a nu mai da la "bisnitarii" de pe okazii 500 000?!
cei care l-ati instalat deja , am postat o intrebare mai sus : se vede full scrren atat portrait cat si landscape?! :wallbesh:
STIMA su RESPECT celor care ajuta :coolup:
maja_ro
566 mesaje
din 24/02/2009
SAMSUNG-SGH-i900
21 martie 2009, 00:40:04
parerea mea e ca daca ar fi reusit intradevar sa-l puna pe telefon si sa si mearga, ar fi postat pasii pas cu pas cum a facut.
nu ar fi dat copy/paste la niste instructiuni gasite pe alt forum
sau poate asteapta baiatu sa sarim cu banii
mikem1
79 mesaje
din 27/02/2009
21 martie 2009, 17:02:02 • actualizat 21 martie 2009, 17:02:50 (1 ori)
Salut la toti
Scuze ca nu am reusit sa raspund la intrebari pana acum dar am fost plecat prin tara si doar acum m-am asezat la PC.
Sa o luam cu inceputul :
- l-am instalat pe Omnnia respectand pasii pe care i-am spus
- se vede full in toate pozitiile portrate/landscape fara nici o problema
Hai sa va spun cum am facut eu si nu am intampinat nici o problema.
1. in primul rand am avut setat Omnia la comunicare pe USB - "Storage card" (eu folosesc un card de 4Gb)
2. am instalat GarminMobileXTforWindowsMobile_50020w
3. am instalat GarminMobileXTFreeBasemap_4xxxx
4. am instalat GarminMobileXTSupportFiles_4xxxx
5. am pornit Garmin pe Omnia si iti apare ca nu are licenta. M-am dus pe "Connect to a Garmin GPS" ( este scris cu alb pe fond albastru din cate imi amintesc).M-am dus in setari - "about" si am scris undeva "CARD ID" si am inchis Garmin.
6. Am deschis Garmin_kgen_15.exe si am generat codul de deblocare pt. Garmin.L-am copiat in sw.unl iar fisierul l-am pus in directorul Garmin langa executabil. RESTARTATI TELEFONUL. La pornire nu a mai cerute cod.
7. Tot cu Gamin _kgen_15 am generat codul de deblocare pt. harta. Am introdus Card ID si codul de harta 1189. L-am copiat in gmapsupp.unl iar fisierul l-am pus in directorul Garmin langa executabil.
8. Pentru harta am instalat Mapsource si dupa instalare mi-a cerut sa deblochez harta Romaniei. Am folosit codul generat mai devreme. Daca Mapsource nu va cere sa deblocati harta vedeti ca aveti in Start - Mapsource - ultima linie ( nu stiu cum se numeste ca nu sunt pe calculatorul unde am instalat Mapsource)unde se deblocheaza harta.
9.Dupa ce am deblocat Mapsource va apare pe ecran o harta a Romaniei si cu vecinii. Selectati toata harta si o sa vedeti ca se va ingalbeni doar harta Romaniei. In parte stanga a programului o sa va apara toate rutele din Romania.
10. Conectati telefonul, dati export si dupa terminare exportului, deconectati tel. Cand porniti Garmin o sa va spuna ca trebuie sa activati) sau ceva de genul asta)harta.
Si cam asta este.
Sper ca nu am uitat ceva. Cand am instalat Garmin nu am intampinat nici o problema.In arhiva exista si un fisier txt de ajutor.
Ce am constatat dupa o folosire de vreo 600km este ca are foarte multe adrese, dar cand este sa recalculeze o ruta poate sa dureze si 1min(cel putin la mine). Consuma mai putina baterie decat IGO8. Eu il folosesc cand vrea sa gasesc o adresa exacta, avand si IGO pe Omnia.
Sper ca v-am raspuns la intrebari sau probleme si daca mai este ceva ne mai auzim.
Pentru "maja_ro" ... este bine sa ai pareri, dar tinele pt. tine : "parerea mea e ca daca ar fi reusit intradevar sa-l puna pe telefon si ...."
adyy35
95 mesaje
din 05/03/2009
21 martie 2009, 20:06:31
deci
se copie harta romaniei
dar nu stiu
cum faci chestioa aia]
export
unde apare sa dai export ????
please..
facaoaru
24 mesaje
din 28/02/2009
21 martie 2009, 23:14:54
dar nu apare export
cauta send to device
Bandrei
924 mesaje
din 11/03/2006
11 aprecieri
22 martie 2009, 04:38:57
merge pus si pe htc diamond? are harta pentru canada?
In vin e puterea,in bere e sanatatea,in cognac e distinctia...(iar in apa sunt microbii!)
adyy35
95 mesaje
din 05/03/2009
22 martie 2009, 06:13:00
deci
daca a reusit cineva sa-l puna pe omnia
sa zica mai clar
cum a facut
dau akolo
transfer - send to device
dar imi da..error information
sa ne zica....
mersi
facaoaru
24 mesaje
din 28/02/2009
22 martie 2009, 10:06:46
eu am reusit sa il pun
daca faci cum a spus mikem1 e relativ usor
ii dai ''send to device''dupa ce ai selectat harta [trebuie sa se ingalbeneasca]
Înapoi la Samsung Omnia
Inițiator acum 17 ani
mikem1
Ultimul acum 14 ani
BachuS
0.031⋅4⋅6
