Full Product Description
Route66 Mobile 7 - GB/IRL - Windows Mobile Software
Features:
You must have a PC with a USB port, a memory card reader/writer, a memory card (256 MB) and a Bluetooth GPS receiver to use this product
Navigate in Britain and Ireland from door to door on your Windows Mobile smartphone
The most complete GPS navigation solution
No more traffic jams thanks to FREE real-time traffic information (in GB)
Extremely fast re-routing in case of deviation from the original route
Accurate and in-time navigation instructions
Quick address look-up thanks to FuzzySearch™ address search engine
New:
Smooth map display thanks to interpolation of GPS signal (I-GPS)
Uninterrupted navigation in tunnels and urban areas thanks to extrapolation of GPS signal (E-GPS)
On-screen exit information like on signposts along the road
Latest geographic data (NAVTEQ, Q1-2006)
No more speed tickets thanks to a clever warning system when exceeding a preset speed limit
Direct dialing to hotels, restaurants, etc. to make for example a reservation
Always driving on the correct lane thanks to lane advice when approaching crossings
Contents of this pack
Your smartphone must have the following specifications:
A free slot for an extra memory card
Windows Mobile 5 Smartphone operating system
16 MB free runtime memory
Not compatible with Sony Ericsson UIQ and Nokia S40/S60/S80/S90
Optional: a GPRS internet connection to access up-to-date traffic information
Features:
New:
Navigation software, geographic map and user manual (CD)
Quick Start Guide
Installation guide
Smartphone NOT included in this pack
System requirements
Nota
Cineva sa faca un mirror in alta parte pentru ca nu va sta mult pe RapidShare
Nu am cauta dar daca exista un topic...sa mute continutul...unul din moderatori in el...si scuze
