Schimbare de soft la modelele Motorola
9153 vizualizări
Scris de SPIDERPC la 26 martie 2008, 06:34:34
Acest tutorial este valabil pentru urmatoarele modele: Motorola A1000, Motorola A1200, Motorola A1200e, Motorola A728, Motorola A732, Motorola A780, Motorola A835, Motorola A840, Motorola A845, , Motorola A920, Motorola A925, Motorola Accompli 388c, Motorola C113, Motorola C113a, Motorola C115, Motorola C116, Motorola C117, Motorola C118, Motorola C139, Motorola C140, Motorola C168, Motorola C257, Motorola C261, Motorola C330, Motorola C350, Motorola C350L, Motorola C380, Motorola C390, Motorola C450, Motorola C550, Motorola C650, Motorola C651, Motorola C975, Motorola C980, Motorola E1 ROKR, Motorola E1000, Motorola E1060, Motorola E1070, Motorola E1120, Motorola E2 ROKR, Motorola E3 ROKR, Motorola E365, Motorola E398, Motorola E398/Е1, Motorola E550, Motorola E6 ROKR, Motorola E680, Motorola E690(ROKR E6), Motorola E725, Motorola E770v, Motorola E815, Motorola E895, Motorola F3 MOTOFONE, Motorola i560 Nextel, Motorola i605 Nextel, Motorola i880 Nextel, Motorola K1 KRZR, Motorola K3 MOTOKRZR, Motorola L2, Motorola L6, Motorola L6i, Motorola L7 SLVR, Motorola L7e SLVR, Motorola L9 MOTOSLVR, Motorola M1000, Motorola MPx 200, Motorola MPx 220, Motorola MS250, Motorola MS280, Motorola MS300, Motorola MS550, Motorola Q, Motorola T720, Motorola Talkabout 192, Motorola U6 PEBL, Motorola V1000, Motorola V1050 , Motorola V171 si Motorola V80.
      Aveti nevoie de cablu de date, drivere, programul RSD si, evident, un soft compatibil pe care doriti sa il instalati. Pasii pe care trebuie sa ii urmati:
  • Descarcati driverele P2K: http://www.sharemobile.ro/file.php?id=88787 .
  • Dezarhivati fisierul RAR. Veti obtine un folder cu 7 fisiere. Clic dreapta pe fiecare dintre fisierele cu exntesia INF si alegeti Install (toate in afara de P2k.sys).
    /data/files/oldpubfiles/1-instalare-drivere.PNG
    Si, totusi, daca dupa ce ati instalat driverele apare Found New Hardware Wizard, selectati No, not this time, apasati Next apoi selectati Install from a list or a specific location (Advanced), apasati Next, bifati Search for the best driver in this locations si apoi Include this location in the search si la Browse alegeti folderul care contine driverele P2K. Repetati acest pas de cate ori va apare Found New Hardware Wizard (va apare de 3 ori: pentru Accessories Interface, Data Logging MCU Interface si Test Command Interface). Daca mai sunt necesare si alte drivere, instalati-le de pe internet cu ajutorul Found New Hardware Wizard.
  • Conectati telefonul la calculator prin cablu de date.
  • Descarcati si instalati programul RSD: http://www.sharemobile.ro/file.php?id=22762 .
  • Deschideti RSD. Daca telefonul a fost detectat, in lista apare modelul, portul, codul IMEI, starea in care se afla telefonul, etc. si puteti continua.
    /data/files/oldpubfiles/2-telefon-detectat.PNG
  • Apasati butonul ... si selectati softul (fisierul ales trebuie sa fie in format SHX sau SBF).
    ATENTIE! Softul trebuie sa fie compatibil cu versiunea de bootloader a telefonului. De exemplu, chiar daca stiti ca softul e pentru E770 trebuie sa verificati daca e compatibil si cu versiunea de bootloader. Pentru E770 sunt 3 versiuni de bootloader: 0.6.7.1, 0.6.8.1 si 0.6.8.4. Daca un model E770 are versiunea de bootloader 0.6.8.4 si incercati sa puneti soft pentru 0.6.7.1, riscati sa va deteriorati telefonul. Pentru a afla ce versiune de bootloader are telefonul procedati astfel: inchideti telefonul apoi tineti apasate tastele * si # si apasati tasta de deschidere a telefonului (cea rosie, de obicei) pana apare o imagine asemanatoare cu aceasta:
    /data/files/oldpubfiles/4-bootloader.gif
    Ca sa iesiti, inchideti telefonul si deschideti-l normal.
  • Daca softul selectat e un fisier valid, la File Properties apar date despre el:
    /data/files/oldpubfiles/3-soft-start.PNG
    ATENTIE! Inainte de a apasa Start verificati sa aveti bateria complet incarcata pentru a nu intampina probleme cum ar fi inchiderea telefonului in timpul sesiunii de instalare.
    Pentru a porni resoftarea apasati butonul Start si asteptati incheierea tuturor pasilor (sunt 3). La sfarsit, cand apare la Status, ca telefonul trebuie sa se restarteze, restartati-l manual daca nu se restarteaza automat.
Comentarii articol 9
22 ianuarie 2011, 10:08:11
gagacata
o rugaminte am un motorola l6 si nu gasesc soft in limba romana vre-o propunere plz
10 decembrie 2010, 12:31:56
linux91
dupa ce ai dat start iti apare eroarea ? sau cand incarci firmware-ul
....mai verifica sa ai driverele instalate bine
02 decembrie 2010, 21:00:17 • actualizat 02 decembrie 2010, 21:02:38
golgota
am ancercat sa resoftez moto a1000 si la mine scrie--internal error while programing phone---oare de ce scrie asa?am urmat toti pasii necesari care se cereau
04 iunie 2009, 10:16:53
slave2anubis
eu zic sa nu mai urmati... acest tutorial ca e cam depasit... decat sa va chinuiti sa le re-inviati din-nou mai bine lasatil!!! trebuie completat...
22 septembrie 2008, 23:11:23
Descarci toate fisierele intr-un folder apoi le unesti cu HJSPLIT. Va rezulta o arhiva RAR care o dezarhivezi si obtii fisierul shx.
22 septembrie 2008, 22:07:11
DjZuZu
nu imi merge sa resoftez un motorola K1v...dc??trebuie si alte softuri sau kit-uri?nu sunt incepator in calculatoare!le am cat de cat dar nu reusesc sa il fac sa mearga!cum sa fac sa aduc softul care l-am downloadat de pe acest site in tipul fisierului pe care trebuie sa-l instalez pe tel?pentru ca ele sunt .rar si imi trebuie .shx??ast rasp mersi
25 iulie 2008, 22:34:00 • actualizat 26 iulie 2008, 00:04:20
Drivere reactualizate (foarte recomandat pentru resoftarile telefoanelor mai noi): http://www.sharemobile.ro/file.php?id=198831 . :) Instalati aceste drivere ca sa nu intampinati probleme.
28 mai 2008, 23:59:20 • actualizat 29 mai 2008, 00:00:03
Cum adica a 'crapat'? :hmm: Daca telefonul inca se mai aprinde si crezi ca e o eroare de soft si nu una tehnica, poti incerca sa il resoftezi urmand acest tutorial. :)
24 mai 2008, 13:01:21
paranoia5h
hmmm foarte interesant tutorialul... dar mie tocmai mi-o crapat softul la telefon... crezi ca am sa reusesc sa il resoftez??
e vorba de un a1000
Aricolul "Schimbare de soft la modelele Motorola" are un scor de 5 din 5 (1 voturi)
0.025⋅4⋅6
