Decodare Nokia BB5 6280 6630 6680 N70 N90 +
133 745 vizualizări
385 răspunsuri
radud5
39 mesaje
din 01/03/2006
03 aprilie 2006, 13:01:28
Am observat ca nu mai pot raspunde pe topicurile cu decodari. :down:
Totusi am o intrebare, telefoanele Nokia BB5 6280 6630 6680 N70 N90, se pot decoda prin cod generat de un program?
A incercat cineva link
Edited by DSF at 08-04-2006, 22:10
UPDATED:
Acum e posibil sa-l decodati si acasa! Decodati pe propria raspundere.
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!!
by Dejan Kaljevic
Need :
1. BB5_Logger by Dejan Kaljevic
2. DKU-5 or ca-43 cable
Procedures :
1. install dku-5 or ca-43 cable
2. go to device manager and check what comport it was installed.
3. now go to downloaded software, click install.bat
you should see this, ignore the error
4. go to C:\logs and look for bb5_unlocker.cfg
5. open with notepad and edit comport same as port at device manager
Note : you can also lower the port number at device manager e.g. COM8
and edit bb5_unlocker.cfg to COM8:
6. run software, you should see this
7. connect phone (powered on) to cable click read phone, info’s will be seen
8. click Make Log and files will be written at folder C:\logs
Note: auto backup files will be created to reset unlock counter
9. click BB5_calc.exe you should see this :
10. click spunlock and smile :)
FAQ
1. if phone spunlock is FFFFFFFFFFFFFFFFF it means spdata corrupt.
you can TRY using BB5 rpl to repair then UNLOCK the phone
2. if unlock tries is around 6 or 8, click write backup and phone will
be restored to its state WHEN IT WAS READED.
3. invalid reading pm. means you change phones too fast and its
reading the IMEI of the first phone and reading the PM of the 2nd phone
(usually happens when many phones are being unlock)
big thanks and credits goes to dejan and Boban.
br.
nlogomaster.
dedicated for non believers 
(documentul contine si screenshoot-uri din program)
Unlock_BB5.doc
http://www.sharemobile.ro/file.php?id=8851
Mai multe detalii pe topicul:
Decodari si resoftari ! Nou ! Decodari BB5 ! Orice retea, pe loc !
Edited by admin at 20-05-2007, 13:28
3dWARd
2011 mesaje
03 aprilie 2006, 13:15:29
dupa parerea mea asta e o MARE pacaleala :(
mircea
4121 mesaje
din 21/08/2005
03 aprilie 2006, 13:19:05
radu, cumpara tu programul si daca ai noroc si merge, scoti ceva bani din chestia asta!  ;)
alcris
73 mesaje
din 07/12/2005
03 aprilie 2006, 15:48:23
Cati bani ar face unii oameni daca ar avea un asemenea code generator! Dar din toate forumurile gsm pe care le-am citit pana acum, pe tema aceasta, n-a aparut nimic! Tare as mai avea nevoie de un asa programel!  :D
Iubitel
1224 mesaje
din 13/01/2006
Nokia6630
03 aprilie 2006, 15:50:38
Peste tot se cauta de decodat astfel de telefoane.S-ar scoate bani multi!
Juma de tara umbla trasa sau beata
Condusa de-un concitadin cu apucaturi de fata...
Wm sux,ups  ;)
3dWARd
2011 mesaje
03 aprilie 2006, 16:30:11
NU E ADEVARAT!
Daca era, fiti siguri ca intai aparea platit(macar) pentru "scule". deci, o sa mai dureze pana se vor face si mai mult ca sigur nu vor aparea generatoare inaintea celor de la sarasoft sau j.a.f. asa ca :down:
razvan_shef
3691 mesaje
din 29/09/2005
03 aprilie 2006, 18:11:00
este clar tzeapa... daca era adevarat nu il vindea cu 5 dolari... il vindea cu 500 ! . daca vreti riscati`va  :D .... in fond...ce mai e 150.000 in ziua de azi ?  :D
cicisxn
1733 mesaje
din 03/05/2005
03 aprilie 2006, 22:25:23
lol,pg ala l-am avut si eu. "facea" 6630,6680...eh,dupa 5min l-am sters. E clar de ce!
[img]http://www.danasoft.com/sig/cicisxn.jpg[/img] [img]http://img149.imageshack.us/img149/103/61164238891mf6.png[/img]
radud5
39 mesaje
din 01/03/2006
08 aprilie 2006, 18:49:50
Am gasit alt program Phoenix BB5 de decodat telefoane BB5, 6630 si 6680
Geopsi
08 aprilie 2006, 20:08:58
radud, tu ai decoat ceva cu ala?
radud5
39 mesaje
din 01/03/2006
08 aprilie 2006, 21:02:12 • actualizat 08 aprilie 2006, 21:04:59 (3 ori)
nu l-am folosit, dar din cate am citit pe alte forumuri 6630 si 6680 se pot decoda folosind algoritmul Griffin 2,6....
3dWARd
2011 mesaje
08 aprilie 2006, 22:58:21
Decodari 6680 vodafone portugalia.
Pentru informatii suplimentare, inbox me!  ;)
mircea
4121 mesaje
din 21/08/2005
09 aprilie 2006, 00:28:20 • actualizat 09 aprilie 2006, 01:35:32 (1 ori)
cine ma ajuta cu un lock code pt 6630? pls!!!
edit: done!  :D
3dWARd
2011 mesaje
09 aprilie 2006, 00:36:02
mIRCea 09-04-2006 00:28:20
verifica PM :coolup:
harletz
3 mesaje
din 16/04/2006
17 aprilie 2006, 18:23:40
Deci pana la urma ... nokia 6630 se decodeaza sau nu ca il arunc pe geam ... m`am plictisit de atata cautat. vreau un raspuns clar si la obiect. si daca face cineva treaba asta sa imi zica cat ma costa...da nu 100 de euro cat mi-au mai zis unii de prin regie ca nu dau atatia bani !
astept raspuns !!
Cursaru
Înapoi la Decodari
Inițiator acum 12 ani
radud5
Ultimul acum 8 ani
smecherasu92
  • E frumos dar nu prea 23% ⋅ 30
Au votat 129 utilizatori
0.020⋅4⋅6
