Instructiuni UPDATE ⤡
Backup ROM SPV C600
[/EDIT]
Deja au inceputa sa apara update-uri pentru Spv C600. Unul dintre acestea este oficial de la Orange:
Upgrading your SPV C600 to provide you with push email
Set up Real Time Microsoft Outlook on your SPV C600.
As part of our commitment to enable Customers to get the most from their devices, Orange are now enabling all existing SPV C600 users to set up access to real time MS Outlook. Imagine that, emails and calendar updates automatically sent and received from you mobile device as well as access to all your tasks and contacts on the move.
Pagina oficiala: Orange Update
Un alt Rom este cel folosit pe iMate SP5, iata noile facilitati:
Addition of the MSFP allowing Direct Push email, remote device wiping, security policy enforcement and Global Address List Lookup for customers using a Microsoft Exchange Server 2003 with Service Pack 2.
File beaming over Bluetooth:
It is now possible to beam files over Bluetooth using the file manager.
Improved radio functionality:
Microphone level has been boosted.
Cell Broadcast display is now supported.
Line2 functionality introduced.
Busy Tone corrected.
Improved the echo suppression.
USSD service support is upgraded.
Updated MMS:
MMS will now operate until there is only 1 Mb of free storage space. Previously this limit was set at 4Mb.
MMS client updated to the current version
Improved Pocket Internet Explorer:
Frames functionality now supported in the browser.
Quick navigation using Page Up key (key 2) and Page Down key (key 8).
Keypad Light Timing:
The timeout of the keypad light can now be set. There is a utility in the 'Utilities' section of the SP5m support pages that will let you set it. Note that setting the keypad light over 8 seconds will cause significant reduction in battery life.
Voice Dial:
Voice Dial reliability from handset has been improved.
Communication Manager:
Communication Manager has been updated to allow current data services to be stopped, Direct Push email to be started/stopped using a single button press, and flight mode to be switched on/off.
Reminders:
When the device is locked, calendar reminders can be snoozed by using the joystick. Previously it was only possible to press the numeric key associated with the menu option to snooze a reminder.
Bluetooth:
Car Kit interface: Address book sync can now be performed to car kits.
Bluetooth Beaming from file manager has now been improved (more reliable and faster).
Java:
Updated Java client to latest version.
Si cateva screenshot-uri:
Acum sa vedem cine se baga la un update de rom.
Multumiri lui DSF pentru informatii.
, nu vreau sa ii fac ceva la soft si sa nu mai mearga cum trebuie
si ink ceva, se instaleaza greu ? trebuie ce aplicatii, se instaleaza pe card,daca nu cata memorie mai ramane in telefon ? thx
