Motorola Milestone
2 373 vizualizări
32 răspunsuri
BGMARIAN
177 mesaje
din 05/02/2008
28 iunie 2010, 22:29:06 • actualizat 28 iunie 2010, 22:30:00 (1 ori)
Ei domnilor, va invit aici sa discutam despre acest minunat telefon.
General:
2G Network: GSM 850 / 900 / 1800 / 1900
3G Network:
- HSDPA 900 / 2100
- UMTS 850 / 1900 - American version
Announced: 2009, November
Status: Available. Released 2009, November
Size:
Dimensions: 115.8 x 60 x 13.7 mm
Weight: 165 g
Display      Type: TFT capacitive touchscreen, 16M colors
Size: 480 x 854 pixels, 3.7 inches
- Multi-touch input method
- Accelerometer sensor
- Proximity sensor for auto turn-off
- Full QWERTY keyboard with 5-way navigation key
Sound:
Alert types: Vibration; MP3, WAV ringtones
Speakerphone: Yes, with stereo speakers
- 3.5 mm audio jack
Memory:
- Practically unlimited entries and fields, Photo call
- Call records      Practically unlimited
Internal: 133 MB storage, 256 MB RAM
Card slot: microSD, up to 32GB, 8GB included, buy memory
Data:
GPRS: Class 12 (4+1/3+2/2+3/1+4 slots), 32 - 48 kbps
EDGE: Class 12
3G: HSDPA, 10.2 Mbps; HSUPA, 5.76 Mbps
WLAN: Wi-Fi 802.11 b/g
Bluetooth: Yes, v2.1 with A2DP
Infrared port: No
USB: Yes, microUSB v2.0
Camera
Primary: 5 MP, 2592 x 1944 pixels, autofocus, dual-LED flash
Features: Geo-tagging
Video: Yes, D1 (720x480 pixels)@24fps
Secondary: No
Features
OS: Android OS, v2 (Eclair)
CPU: ARM Cortex A8 600 MHz, PowerVR SGX530 graphics
Messaging: SMS (threaded view), MMS, Email, IM, Push Email
Browser: HTML
Radio: No
Colors: Black
GPS: Yes, with A-GPS support, Motonav software
Java
- Digital compass
- MP3/eAAC+/WAV/WMA9 player
- MP4/H.263/H.264/WMV9 player
- Google Search, Maps, Gmail,
- YouTube, Google Talk
- Adobe Flash Player v10.1
- Document viewer
- Photo viewer/editor
- Organizer
- Voice memo/dial
- T9
Battery: Standard battery, Li-Ion 1400 mAh (BP6X)
Stand-by: Up to 350 h
Talk time: Up to 6 h 30 min
informatii utile gasiti, printre altele, aici:
http://forums.hardwarezone.com.sg/showthread.php?t=2727572&page=9
Edited by Mishulica at 30-06-2010, 20:35
ady_uaic
1823 mesaje
din 24/06/2006
3 aprecieri
29 iunie 2010, 09:12:24
ma bucur ca-ti place  :P
http://img707.imageshack.us/img707/5567/motorolamilestone1.jpg
http://img189.imageshack.us/img189/4486/motorolamilestone2.jpg
SGS2
BGMARIAN
177 mesaje
din 05/02/2008
29 iunie 2010, 15:21:48 • actualizat 29 iunie 2010, 15:22:51 (1 ori)
pot sa va spun ca eu am urmat pasii din link-ul de mai sus si am reusit sa-mi rootez telu. cititi cu mare atentie fiecare pas si o sa iasa ... ai asa o mare satisfactie cand reusesti, o spun eu un necunoscator in materie..
whiteboy
5940 mesaje
din 01/03/2008
29 iunie 2010, 15:23:49
ce pret a avut telefonul? :)
BGMARIAN
177 mesaje
din 05/02/2008
29 iunie 2010, 15:27:50 • actualizat 29 iunie 2010, 15:46:15 (1 ori)
14 mil de pe internet
acum urmeaza app2sd dar nu inteleg urmatoarele:
Type: cd/ (to get to the root of your C: drive)
Type: cd /android/tools (to get to the folder of the Android SDK which i mentioned earlier)
Type: adb devices (you should see your Milestone serial number showing up. If you do not see serial number, it means there is no connection to your Milestone)
Type: adb shell
Type: su (make sure you do not see a prompt window on your Milestone. If you do, grant permission for it to access)
Type: cd /sdcard/app2sd
Type: sh install_use_busybox.sh (trigger installation of App2SD)
Type: y (to confirm that you want to install)
wait for the prompt to show you that App2SD is complete and a reboot is needed for it to take effect.
Type: y (to confirm reboot. You might notice that Milestone do not reboot by self which is normal)
Type: reboot (if you find Milestone do not reboot after you enter y as above mentioned)
unde fac acest "Type" ??
PhenNnom
2436 mesaje
din 29/07/2008
44 aprecieri
29 iunie 2010, 15:58:49 • actualizat 29 iunie 2010, 16:00:02 (1 ori)
BGMARIAN Type = Tasteaza...Acolo scrie exact asa .Type este instructiunea pe care trebuie sa o urmezi.Deci concluzie :
Tasteaza : cd /sdcard etc..sper ca intelegi.
HP Pavilion G6 # OSX Mavericks + Windows 7
Samsung Galaxy S4 Developer Prototype
nerooo_07
798 mesaje
din 29/08/2009
70% warn
29 iunie 2010, 16:07:46
BGMARIAN 29-06-2010 15:27:50
@BGMARIAN, te rog sa.mi spui cum se aude telefonul, se aude puternic? In comparatie cu Nokia N73, N95?
Poate ai auzit si un Nokia 6234, daca da, se aude mai tare si ca asta? Te rog mult sa.mi raspunzi.
Cat despre pret, nu e chiar atat de mare! :coolup:
laur1989
8382 mesaje
din 17/04/2007
29 iunie 2010, 16:21:14 • actualizat 29 iunie 2010, 16:23:01 (1 ori)
Oameni buni ce aveti ? E atat de important sa urle manelele intr-un device scump ?
Nu cred ca e 1400 Milestone, poate in magazine din astea fantoma. Pleaca de la 500 de euro fara discutie. O sa apra si in oferta Orange.
P.S. Daca tot va apucati sa deschideti un topic, macar sa o faceti ca la carte, nu copy-paste.
nerooo_07
798 mesaje
din 29/08/2009
70% warn
29 iunie 2010, 17:23:40
da man, vreau sa am un device care sa.mi satisfaca toate cerintele!
laur1989
8382 mesaje
din 17/04/2007
29 iunie 2010, 18:23:44 • actualizat 29 iunie 2010, 18:27:41 (2 ori)
Pana acum nu s-a inventat unul care sa faca tot ce doreste utilizatorul. Deschide-ti o fabrica cauta cativa ingineri si iti construiesti device-ul dupa preferintele tale. Ok ? Telefoanele de genul asta nu o sa fie cumparate de pusti care asculta muzica si stau pe messenger...
zapp_user
Acces restricționat
3 mesaje
din 29/06/2010
29 iunie 2010, 21:32:23
Pretul incepe de la 1439 ron (la liber):
http://www.shopmania.ro/magazin~online-telefoane-mobile~produs-motorola-milestone~p-7418341.html
BGMARIAN
177 mesaje
din 05/02/2008
29 iunie 2010, 23:37:38
@Phenomen: da man asta am inteles, dar unde tre sa type?....
@Nerooo_007: http://clickgsm.ro/217-pret-motorola-milestone.html? cam asta am gasit acum, cat despre sunet pot doar sa compar cu htc sau sonyericsson, pt mine noika nu exista, nu vreau sa te supar :-) dar sa stii ca in timpul convorbirii se aude foarte bine, cred ca merg la jumate cu volumul si mi se pare tare. reda super bine video, am filmat la niste concerte si am ramas surprins ce bine reda si se aude, comparativ cu htc pro2...muzica nu ascult de pe el, dar e ok
ei laur1989, unii oameni sunt mai pretentiosi, tre sa-i intelegem si pe ei...daca esti la orange poti sa ti-l iei, daca a aparut, eu l-am luat de la un dealer vodaf de pe stefan cel mare, e adus din germania ca scrie in germana pe cutie si are si sigle vodaf.
BGMARIAN
177 mesaje
din 05/02/2008
30 iunie 2010, 15:40:52
off mi se zburleste parul in cap.... vreau sa instalez Android SDK...
trebe toate astea http://forum.xda-developers.com/showthread.php?t=502010 uff
Raoul
12436 mesaje
din 09/01/2006
16 aprecieri
40% warn
30 iunie 2010, 16:31:21
Cat ai dat pe el? Poti uploada un video filmat cu el?
laur1989
8382 mesaje
din 17/04/2007
30 iunie 2010, 16:48:37 • actualizat 30 iunie 2010, 16:49:19 (1 ori)
BGMARIAN 29-06-2010 23:37:38
Sa-l butonezi sanatos. La Orange este 375 de euro prelungire contract 24 luni sau 385 de euro prelungire contract 12 de luni la abonament de 4 euro (TVA inclus) fara alte optiuni. Pretul la liber este 435,54 euro.
Înapoi la Android OS
Nikku
acum 9 ani
838 vizualizări
Inițiator acum 10 ani
BGMARIAN
Ultimul acum 7 ani
costyy86
0.035⋅6⋅4
