Coduri telefoane mobile
43 011 vizualizări
288 răspunsuri
ArkAngel
972 mesaje
din 06/06/2005
17 iunie 2005, 12:48:59
Postatzi, va rog coduri pt orice tip de telefon. Pt cei care au nevoie de ele :)
Nokia Life Timer code: *#92702689# (pentru a afla cat s-a vorbit de pe un telefon Nokia)
Edited by admin at 27-02-2008, 17:43
Flying... ArkAngel! MobileWave
Vizit my Hi5 account
Ex Codyms
3dWARd
2011 mesaje
19 iunie 2005, 00:22:32 • actualizat 19 iunie 2005, 01:30:29 (2 ori)
Astea sunt pentru nokia 6600  ;)
*#0000# firmware version
*#06# IMEI number
*#7370# format your phone.
*#7780# similar to *#7370#
*#2820# to find out the bluetooth ip address of the phone
*#res0wallet# erase all data stored in the wallet.
Green, *, 3 to format the phone, turn off and hold these keys while phone is rebooting. do not let go until "formatting" appears and make sure you have enough battery power (3/4 minimum)
Cine vrea coduri pentru un anumit model de telefon, sa posteze aici si am sa incerc sa ii rezolv problema  ;)
3dWARd
2011 mesaje
19 iunie 2005, 01:05:33 • actualizat 19 iunie 2005, 01:35:02 (5 ori)
tot pentru nokia , dar de data asta, petru modele mai vechi  :D :))
*3370# This nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#0000#      Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999#      Phones software version if
*#0000# does not work
*#06#      For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1#      Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2#      Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3#      Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4#      SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147#      This lets you know who called you last (Only vodofone)
*#1471#      Last call (Only vodofone)
*#21#      This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#30#      Lets you see the private number
*#43#      Allows you to check the "Call Waiting" status of your cell phone.
*#61#      Allows you to check the number that "On No Reply" calls are diverted to
*#62#      Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67#      Allows you to check the number that "On Busy Calls" are diverted to
*#67705646#      Phone code that removes operator logo on 3310 & 3330
*#73#      Reset phone timers and game scores
*#746025625#      Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760#      Manufactures code
*#7780#      Restore factory settings
*#8110#      Software version for the nokia 8110
*#92702689#      Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789#      Deactivate the PWM-Mem
**21*number#      Turn on "All Calls" diverting to the phone number entered
**61*number#      Turn on "No Reply" diverting to the phone number entered
**67*number#      Turn on "On Busy" diverting to the phone number entered      12345      This is the default security code
press and hold #      Lets you switch between lines
sper sa intelegeti ceva si sa nu trebuiasca sa le reasez  :D
3dWARd
2011 mesaje
19 iunie 2005, 01:11:50 • actualizat 19 iunie 2005, 01:37:34 (2 ori)
Si unele pentru sony-ericsson
there is a cool code that lets you view and test everything on sony ericsson phone such as t610 and k700i so far (basically any with a joystick on!!) the first one is > * < < *< * this brings up service tests and service info. the other code is < * * <
3dWARd
2011 mesaje
19 iunie 2005, 01:14:01 • actualizat 19 iunie 2005, 01:39:37 (1 ori)
Alcatel
IMEI number: * # 0 6 #
Software version: * # 0 6 #
Net Monitor: 0 0 0 0 0 0 *
3dWARd
2011 mesaje
19 iunie 2005, 01:25:03
si....de ce nu, si pentru telefoane mai vechi....ca deh...  :P
Bosch
Default Language: * # 0 0 0 0 #
Net Monitor: * # 3 2 6 2 2 5 5 * 8 3 7 8 # #
3dWARd
2011 mesaje
19 iunie 2005, 01:41:52
Dancall
Software version: * # 9 9 9 9 #
SIM card serial number: * # 9 9 9 4 #
Information about battery status: * # 9 9 9 0 #
Selftest (only Dancall HP2731): * # 9 9 9 7 #
Show version configuration: * # 9 9 9 8 #
Net Monitor: * # 9 9 9 3 #
3dWARd
2011 mesaje
19 iunie 2005, 01:43:26
Motorola
Net Monitor ON: * * * 1 1 3 * 1 * [OK]
Net Monitor OFF: * * * 1 1 3 * 1 * [OK] * - press this until box shown up
3dWARd
2011 mesaje
19 iunie 2005, 01:45:56
Philips
Simlock info: * # 8 3 7 7 #
Security code: * # 1 2 3 4 # (Fizz) or * # 7 4 8 9 #
3dWARd
2011 mesaje
19 iunie 2005, 01:47:43 • actualizat 19 iunie 2005, 01:50:17 (1 ori)
Samsung [i](Most models)[i]
Albo* # 0 8 3 7 #
Net Monitor: * # 0 3 2 4 #
Changing LCD contrast: * # 0 5 2 3 #
Memory info: * # 0 3 7 7 #
Albo * # 0 2 4 6 #
Reset CUSTOM memory: * 2 7 6 7 * 2 8 7 8 #
Battery state: * # 9 9 9 8 * 2 2 8 #
Alarm beeper: * # 9 9 9 8 * 2 8 9 #
Vibra test: * # 9 9 9 8 * 8 4 2 #
3dWARd
2011 mesaje
19 iunie 2005, 01:53:21
Samsung (T100 Specific Codes)
Battery status (capacity, voltage, temperature): * # 8 9 9 9 * 2 2 8 #
Program status: * # 8 9 9 9 * 2 4 6 #
Change Alarm Buzzer Frequency: * # 8 9 9 9 * 2 8 9 #
Debug screens: * # 8 9 9 9 * 3 2 4 #
Watchdog: * # 8 9 9 9 * 3 6 4 #
EEPROM Error Stack: * # 8 9 9 9 * 3 7 7 #
Trace Watchdog: * # 8 9 9 9 * 4 2 7 #
Change LCD contrast: * # 8 9 9 9 * 5 2 3 #
Jig detect: * # 8 9 9 9 * 5 4 4 #
Memory status: * # 8 9 9 9 * 6 3 6 #
SIM File Size: * # 8 9 9 9 * 7 4 6 #
SIM Service Table: * # 8 9 9 9 * 7 7 8 #
RTK (Run Time Kernel) errors: * # 8 9 9 9 * 7 8 5 #
Run, Last UP, Last DOWN: * # 8 9 9 9 * 7 8 6 #
Software Version: * # 8 9 9 9 * 8 3 7 #
Test Vibrator: * # 8 9 9 9 * 8 4 2 #
Vocoder Reg: * # 8 9 9 9 * 8 6 2 #
Diag: * # 8 9 9 9 * 8 7 2 #
Reset On Fatal Error: * # 8 9 9 9 * 9 4 7 #
3dWARd
2011 mesaje
19 iunie 2005, 01:55:55
Sagem
Service Menu access: MENU 5 1 1 #
3dWARd
2011 mesaje
19 iunie 2005, 01:57:09
Siemens
Software version: Take out SIM & enter: * # 0 6 # (& press LONG KEY)
Bonus screen: in phone book: + 1 2 0 2 2 2 4 3 1 2 1
Net Monitor (S4 Power):
Menu 9 8, left SoftKey, 7 6 8 4 6 6 6, Read phone, Menu 5 6
ArkAngel
972 mesaje
din 06/06/2005
20 iunie 2005, 23:10:17
3DwarD cauta nishte coduri pt nokia N-gage sau N-gage QD please  :D
Ex Codyms
3dWARd
2011 mesaje
24 iunie 2005, 11:44:10
Codes for Tomb Raider on Nokia N-Gage
Secret Panel
38018
To find the secret panel unscrew the back of the n-gage and remove battery. You should now see a panel. Using a screwdriver, open the panel. You should see a red button. Press it, then turn on the N-gage with the battery replaced. You now have free access to a game download site which is free.
Înapoi la Trucuri și sfaturi
Inițiator acum 13 ani
ArkAngel
Ultimul acum 6 ani
cs_st3fan
  • E frumos dar nu prea 23% ⋅ 30
Au votat 129 utilizatori
0.025⋅6⋅4
