S-a reusit portarea lui Android OS pe HTC Diamond..
Dar e versiunea 0.8, nu e versiunea disponibila pe T-mobile G1.
Are multu buguri, touch-ul nu e calibrat, etc.
Totusi.. e un inceput.
Pentru cei interesati cititi:
- Linux on Raphael and Diamond
- Linux / Android on Diamond
- [PRJ][OS]Linux and Android on HTC Diamond
Android OS pe HTC Diamond & Touch Pro
13 389 vizualizări
33 răspunsuri
Linkuri topic "Android OS pe HTC Diamond & Touch Pro"
05 noiembrie 2008, 17:09:11 • actualizat 05 noiembrie 2008, 17:09:45 (1 ori)
731 mesaje
din 01/04/2008
05 noiembrie 2008, 20:49:37
Am urmarit pe you tube cateva filmulete cu android.Are intradevar cateva chesti tare faine.Eu il astept cu nerabdare
[IMG]http://i295.photobucket.com/albums/mm139/BigCall/Demonoid-1.jpg[/IMG]
176 mesaje
din 03/09/2008
07 ianuarie 2009, 17:34:55
si cam care sunt avantajele/dezavantajele OS-ului Android daca ar urma sa apara un ROM complet, fara multe buguri etc ?
ma duc acum sa citesc link-urile
si eu il astept cu nerabdare...
08 octombrie 2009, 14:19:20
Ok, a aparut o versiune mai noua.
So far
-Running Donut 1.6
-No random program crashes
-Landscape + Portrait
-Battery life seems to be improved quite abit
-Very responsive. ( pressing on the screen is accurate and doesnt require much pressure, quitting programs and going forward and backwards into screens are instantaneous.)
-Voice synthesis ( soooooooooooo awesome )
-Calls outgoing and incoming working
-Sms outgoing and incoming working
-Light Sensor works ( discovered it randomly )
Downfall
-Some of the sound in the build is crackling. Some files have crystal clear playback whereas other seams to jump and crackle.
-GPRS makes the build freeze the device all up.
-Video also is suffering from jumps and audio crackling. ( further investigation )
(All credit go to the people who made these packs. I just put the files that i had the most compatibility with )
LINK DOWNLOAD DONUT 1.6 test and working on Raph100 and hopefully diamond.
http://www.4shared.com/file/138422517/b4124223/babijoeeDonut16pack.htmlsursa.
Eu acum il testez, nu e interfata asa fluida.. dar na.
PS: copiati continutul arhivei direct pe Storage Card, in root. Daca il copiati intr-un folder nu va rula. Se porneste cu haret.exe
-Running Donut 1.6
Downfall
08 octombrie 2009, 15:21:47
este android si pentru htc touch dual...cam 100 mb ,l-am luat acum cateva zile ... DSF ,schimba si tu numele topicului in ceva gen android pentru telefoane WM ,nu de alta dar pari ca aia care deschid topicurile cu omnia
3348 mesaje
din 27/04/2007
14 aprecieri
Cint are dreptate. De exemplu pe Kaiser se misca excelent Androidul; pacat ca dupa o vreme te plictisesti de el cand vezi cat de multe functii lipsesc sau au bug-uri.
nu. Ce ar fi sa postam intr-un topic rom-uri pt toate telefoanele? Ar fi un haos. Pe x nu-l intereseaza romuri pt alt ppc, ar trebui sa treaca peste n mesaje irelevante. Timp pierdut, organizare proasta.. incercati sa vedeti si din pct asta de vedere...
Si acum ontopic. Am pus alta versiune (xrom), cu asta merg mai bine jocurile, sunetul nu mai sacadeaza, gprs functioneza.. numai ca e mai lent in unele privinte: meniu, revenire in homescreen, typin..
Oricum, android e tare, avand la baza linux, e f flexibil. Are si wget, pi si alte aplicatii linux. . Pacat ca nu cunosc linuxu sa profit de asta. Browserul e mai rapid decat orice e disponibil pe wm.
Daca se rezolva bugurile existente, as trece fericit pe android. The future is android.
Ps. Postat cu greu de pe android os, tastatura are ceva lag.. si cea hardware nu merge cu versiunea asta de xrom
1101 mesaje
din 31/08/2005
Am instalat Android pe Diamond si am si facut setarile wap si scriu de pe el.Merge bine si e stabila versiunea asta. Nu merge gps-ul si camera foto,video.
[img]http://www.fightersoft.ro/mts_user.gif[/img] [img]http://forum.clubford.ro/download/file.php?avatar=13069_1321567490.gif[/img]
1507 mesaje
din 01/06/2005
14 noiembrie 2009, 01:59:38
Ceva update`uri la Android pt Diamond sunt ?
176 mesaje
din 03/09/2008
16 februarie 2010, 19:50:27
205 mesaje
din 04/12/2008
08 martie 2010, 21:32:46
amdownloadat fisierul anterior si are extensia .7z
imi spune cineva ce trebuie sa fac cu fisierul ?trebuie modificata extensia?
5940 mesaje
din 01/03/2008
08 martie 2010, 21:38:18
2437 mesaje
din 29/07/2008
46 aprecieri
08 martie 2010, 21:43:33
Am pus si eu 2.0.1 pe telefon.Daca mai are cineva wap-ul de la orange,poate sa imi confirme daca pe varianta asta merge browsing-ul ?
HP Pavilion G6 # OSX Mavericks + Windows 7
Samsung Galaxy S4 Developer Prototype
205 mesaje
din 04/12/2008
08 martie 2010, 21:57:38
[quote name="whiteboy" time="08-03-2010 21:38:18"]
Download 7-Zip from filehippo.com
o app pentru htc nu stiti pentru acest tip de fisier,? ....momentan nu am pc
205 mesaje
din 04/12/2008
rog pe cineva sa puna http://connect-utb.com/index.php?option=com_rokdownloads&view=file&task=download&id=50:android-for-htc-diamondEnglish Version
pe http://4shared.com sau pe
http://extremshare.net (in doua arhive) ..raman dator ..
Înapoi la HTC Diamond & HTC Touch Pro
