"Huawei E960 HSDPA Wireless Gateway
Supporting two working modes of the wireless gateway and USB modem
Supporting the HSDPA at a rate of 3.6/7.2 Mbit/s for downlink and 384 Kbit/s for uplink
Built-in WCDMA and WLAN high gain antenna, which supports receiving diversity and equalizer
Supporting Web-based management, parameter presetting, and plug-and-play
Ultrathin and artful ID
User-friendly design of indicators
Supporting three placement methods: desktop, desktop inclining, and wall-mounted
Specifications
Item
Specification
Dimensions (Length à— Width à— Height)
155 mm à— 115 mm à— 28 mm
Weight
<500 g
External Interfaces
Four LAN interfaces for the RJ 45
One telephone interface for the RJ11
WLAN: maximum of 32 users
Power supply interface and USB interface multiplex
Indicators
One power supply indicator
One signal type indicator
One indicator for WLAN in service
One signal intensity indicator
Four Ethernet interfaces, each Ethernet interface has a LINK/ACTIVE indicator
Antenna
Built-in antenna
UIM
Supports the R-UIM mode
Operating System (OS)
Windows 2000, Windows XP, Windows Vista, and MAC OS
Band Class
Supports HSDPA/UMTS 2100 M
Supports GSM/GPRS/EDGE 850/900/1800/1900 MHz
Technical Standards
1. HSDPA/WCDMA: 3GPP R5 2004/06
2. GSM/GPRA/EDGE: 3GPP R99 2003/12
Functions
Functions in wireless gateway mode:
High speed data
Voice
Route
LAN and WLAN access
Web-based local management and maintenance
Functions in USB Modem mode:
High speed data
Short message
Phone book
Automatic installation, and plug-and-play
The power is supplied through the USB from the PC. Thus, no external power supply is required.
Others
Passed certifications such as EMC, SAR, CE, ROHS, and GCF
Reliable quality and good compatibility
Abonamentele vor fi Home and Office PACK 12/24 si Office Pack 36.Cam atat stiu deocamdata ,maine cred ca o se merg la Orange Shop sa fac un abonament de genul asta si va pot spune mai multe.
