Winamp
9 665 vizualizări
333 răspunsuri
bunelu
2125 mesaje
din 07/07/2005
10 septembrie 2006, 15:12:44
postati aici plugin-uri, skins, tips & tricks, update-uri etc. :)
This is 10% percent luck, 20% percent skill 50% percent concentrated power of will 5% percent pleasure, 15% percent pain And 100% percent reason to remember the name.
Respect The Rules !
calc
2952 mesaje
din 01/09/2006
MOT-V980M
10 septembrie 2006, 15:17:51
Va rog eu sa postati si linkuri directe :)
bunelu
2125 mesaje
din 07/07/2005
10 septembrie 2006, 15:19:28
EvilLyrics .. un programel super tare care cauta pe net versuri si le afiseaza la fiecare melodie :coolup:
Respect The Rules !
10 septembrie 2006, 15:20:49
This plugin is for those who want bass, much more bass when they listen to music...Of course... i haven't forgotten high frequencies... And yes, i'd almost forgotten, a little 3d... It works for several types of music and it requires a Pentium 166 or better (plus winamp 2.xx or a better version). I believe that this program lays a very good emphasis on low frequencies. If you have a good sound board and a quality audio system, the program will certainly show off its strenghts...
Enhancer
pool8
899 mesaje
din 28/01/2006
10 septembrie 2006, 15:30:27
Pentru skinuri incercati http://www1.1001skins.com/ gasiti o gramada atat clasice cat si moderne :)
Arrow
9475 mesaje
din 30/07/2005
10 septembrie 2006, 16:08:32 • actualizat 10 septembrie 2006, 16:21:38 (2 ori)
Skinuri Almond XMMS pentru Winamp
http://img56.imageshack.us/img56/8828/winampskinbysimzerqm9.png
Cateva skinuri frumoase pentru Winamp
Descarca:aici host: rapidshare
arhiva: 752kb parola arhiva Gangsta@warezBB.ro
creditGangsta
Edit Later
Si daca tot vb de winamp ...ultima versiune full
Winamp Full 5.25 Build 857 Beta
Descarca: aici host :rapidshare
Arhiva: 5,72 mb
credit:Team SnD
JokerBoy
10 septembrie 2006, 16:26:04
poate sa puna arhiva cu skinuri pusa de gaby pe www.yourfilelink.com va rog? ca pe rapidshare vad ca nu-mi arata codul de dld-are
10 septembrie 2006, 16:39:39
Trebuie sa astepti ceva secunde ca sa afiseze codul ala apoi merge
ResuRRectoR
903 mesaje
din 21/05/2005
10 septembrie 2006, 16:44:53
Pluginul pe care il folosesc eu pentru afisarea versurilor : Leo's Lyrics
10 septembrie 2006, 21:52:06
http://www.oldversion.com/program.php?n=winamp pt
versiunile mai vechi de Winamp,care consuma mai putin...
ca alternativa,mai nou am trecut pe coolplayer,mai mic si mai putin consumator de resurse,are cam tot ce are si winamp,inclusiv streaming  :D
pool8
899 mesaje
din 28/01/2006
10 septembrie 2006, 23:19:30 • actualizat 10 septembrie 2006, 23:23:32 (1 ori)
BogdanPlay 10-09-2006 16:26:04
uite aici http://www.yourfilelink.com/get.php?fid=170554
sunt faine skinurile daca ar avea si un set de cursoare ar fi si mai bine
cosmin91ro
848 mesaje
din 15/08/2006
11 septembrie 2006, 05:07:36 • actualizat 11 septembrie 2006, 05:13:23 (3 ori)
DSF 10-09-2006 15:20:49
[quote]This plugin is for those who want bass, much more bass when they listen to music...Of course... i haven't forgotten high frequencies... And yes, i'd almost forgotten, a little 3d... It works for several types of music and it requires a Pentium 166...
Eu l am instalat,da nu stiu sa l pornesc.folosesc winamp 5.1 (parca) Enhancer
<a href ="http://www.foliibrasov.ro" >Pune folii pe masina ta in Brasov, ieftin si omologat</a>
11 septembrie 2006, 08:32:47
te duci la preferinte / plugins si il activezi de acolo. vezi ca sunt sortate pe categorii
xalex
940 mesaje
din 07/03/2006
11 septembrie 2006, 15:03:14
kalumea skinurile
Frike
1507 mesaje
din 01/06/2005
11 septembrie 2006, 20:36:45
este un plugin pt winamp.. at cand asculti muzica se schimba statusu la yahoo mess la ce mel asculti... na pt yahoo 8 daca aveti si este :-D
Android leads the path.....
www.bestbots.ro / Bijuterii Swarovski
Înapoi la Aplicații PC
DRACOSU
acum 13 ani
9
4 970 vizualizări
Winamp pentru SE K800i? în Aplicații Java
Deschis de iviorel ⋅ acum 13 ani
Inițiator acum 14 ani
bunelu
Ultimul acum 5 ani
Claudiu21
Doctor
0.116⋅6⋅4
