PIMP your SE (SonyEricsson Tuning)
19 124 vizualizări
934 răspunsuri
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 21:47:37 • actualizat 04 iulie 2006, 23:50:50 (1 ori)
In acest topic var aparea instructiuni cum iti poti modifica (customixa, tuna SE k750i, w800i si multe altele)
[DUAP CAT AM INTELES DACA MODIFICI CEVA ITI PIERZI GARANTIA]
to be continued...
[img]http://img52.imageshack.us/img52/4769/k7505ir.gif[/img]
cicisxn
1733 mesaje
din 03/05/2005
Nokia6670
04 iulie 2006, 21:49:39
In nici un caz nu cred in "k500 cu WM"
[img]http://www.danasoft.com/sig/cicisxn.jpg[/img] [img]http://img149.imageshack.us/img149/103/61164238891mf6.png[/img]
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 21:50:57 • actualizat 04 iulie 2006, 22:10:04 (2 ori)
Far Manager+Darkman`s plug-in (voi pune si versiunea in limba romana pt. cei mai putin cu SKILU de a citi engleza, cat de curand)
What is the best way to manage files in internal phone FS?
- readout extracting? But now we have ONLY RO access.
- script access is good, but for automatic operations. Write it once and run every time you need.
Now we have alternative way: common file manager with SE Flash Plugin.
Actually i plan to perform 2 things:
1. Filesystem handling
2. Flash custom blocks with unsigned data (usefull for patches)
But have not a lot of free time.
At this moment we can:
-read files
-write files
-move\delete files
-create folders
-delete folders
We can't (yet):
-rename
Phone models supported:
-k300/k500/k700/S700
-k750/w800
Comm devices supported:
-Service cable (COM-interface)
-DCU-60
Installation:
The plugin needs Far Manager v1.705.
-extract archive to ...\Far\Plugins
-restart Far
Executing by Disk Menu (Alt+F1/Alt+F2) - "SEFP" shortcut or Plugin Menu - F11
Configure:
After select SEFP in Disk Menu you'll see connection settings dialog.
http://sephone.nm.ru/images/sefp/sefp_sett1.gif
You must specify Comm Device and speed. Then press Enter
ChipID/platform reading apears next:
http://sephone.nm.ru/images/sefp/sefp_cid.gif
Next you must select phone_start mode - FS folder
Loader uploading apears:
http://sephone.nm.ru/images/sefp/sefp_1.gif
After all uploads ok you'll see phone's root folder:
http://sephone.nm.ru/images/sefp/sefp_2.gif
MPORTENT: ALWAYS DO SHUTDOWN LOADER!!! In other case some of corrections maden will LOST.
From Plugin version 0.6.0.98 PHONE SHUTDOWNS AUTOMATICLY BEFORE EXIT FAR OR DISK CHANGING
Shoutown request apears when you go up from root folder to FS:
http://sephone.nm.ru/images/sefp/sefp_3.gif
sefp.log - is communication log file
PROGRAMS
FAR MANAGER: http://www.yourfilehost.com/media.php?cat=other&file=3300FarManager170.exe
DARKMANPLUGIN: http://www.yourfilehost.com/media.php?cat=other&file=SEFP_07032.zip
CABLE DRIVER(aditional driver):http://www.yourfilehost.com/media.php?cat=other&file=Win_USB_Driver_new.zip
Installation:
1.Instal FAR MANGER
2.Unpack SEFP_07032.zip to Far\Plugins\
3.Restart Far
Diu
4446 mesaje
din 04/09/2005
04 iulie 2006, 22:18:00
Si ce poti face mai exact? Extinzi memoria sau ce? ???
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 22:44:59
Cum sa flashuiesti (trasformi k750i in w800i) gratis (doar pt. telefoanele cu CID 36) doar cu cablu din pachet (DCU-60)
!!!!!INAINTE DE TOATE VERIFICATI DACA AVETI CID 36!!!!!
1. Dw fisierele(MAIN+FS) pt ultima versiune de fost W800i (R1BD001 din: 23-03-2006)
MAIN(dezarhivati): http://www.yourfilehost.com/media.php?cat=other&file=W800_R1BD001_MAIN_EU_1_CA_RED36.rar
FS:http://www.yourfilehost.com/media.php?cat=other&file=W800_R1BD001_FS_EMEA_1_RED36.1.bin
2. Folositi clientul Davinci client 13.7 fara finalizare
http://mikhan.narod.ru/se/k750flasher_13.7.zip
GID DAVINCI:
Aflarea CID-ului
pub/davinci-13.7-test-cable.gif
Incarcati fisierele MAIN si FS, fara finalizare
pub/davinci-13.7-flash.gif
3. Funeti fisierele din arhiva de mai jos in tpa/preset/custom ,folder de pe telefon folder pe care il accesati cu FAR si pluginul lui Darkman
http://rapidshare.de/files/22427315/complete.rar.html
4. Enjoy! (NU UITATI SA SCOATETZI BATERIA SI APOI SA O BAGTI IARA INAINTE SA IL PORNITI)
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 23:08:26 • actualizat 04 iulie 2006, 23:09:01 (1 ori)
CE POTI FACE CU FAR+DARKMAN`s PLUG-in
IMPORTANT : Tot timpu fa backup la fisierele pe care le editezi, si de asemenea o faci pe RISCUL TAU, BAFTA
Marire capacitatea de stocare a SMS-urilor:
1. Intra in folderu /ifs/settings/messaging/ cu FAR Manager
2. Selecteaza pref_store.txt an hit F4
3. Modifica "/smsdata" in "/tpa"
4. Salveaza modificarile
5. Intoarcete la "root" si stinge loaderul
6. Reseteaza telefonu si gata
Seteaza sunetul redat de difuzor (mp3) ca cel de sonerie (volum mult mai superior).
Copiaza pe calculator fisierul farfield_ring.apf aflat in FS/ifs/settings/acoustic si redenumestel farfield_play.apf si apoi inlocuestel cu farfield_play.apf aflat in folderul in FS/ifs/settings/acoustic (dar intai nu uita sa faci un BACKUP la farfield_play.apf de pe telefon). Inchizi loaderul dai reset la telefon si gata
Eliminare sunet de a camera
Dute in FS/tpa/preset/system/sound si sterge camerashutter.3gp , pentru eliminare sunetului de la autofocus sterge camerafocus.3gp. Sau poti sa le schimbi cu ce sunete vrei (iei orice mp3 vrei si il transformi in 3gp il redenumesti cum vrei tu dupa cele de sus).
Eliminare sunetul de la BATERIE DESCARCATA
Intra in FS/tpa/preset/system/sound/lowbattery.mid si inlocuestel cu acelas fisier da cu 0b (adica sa fie gol), sau poti sa il inlocuesti cu un sunet care vrei tu dar sa il redenumesti ca atare.
Shutdown Sound
folderul /fs/tpa/preset/system/settings
pune orice mp3 cu numele SHUTDOWN_SOUND_SEMC.mp3 si inlocuesti sunetul lui standard.
Si multe altele.... (se va updata permanent, cum aflu ceva nou poi modifica )
Fanatique
692 mesaje
din 08/10/2005
04 iulie 2006, 23:11:44
Wow... :clap:
CID-ul nu se poate modifica?  :P  :D
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 23:13:02 • actualizat 04 iulie 2006, 23:20:44 (2 ori)
NOP din pacat nu dar se lucreaza la un plugin care sa suporte si CID 49 asa ca tre sa asteptam si sa speram ca va reusi DARKMAN sa il sparga
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 23:27:00 • actualizat 04 iulie 2006, 23:27:59 (1 ori)
CUM SA ITI CUSTOMIZEZI MENIU
(adica poti rearanja meniu poti pune meniu vertical meniu orizontal meniu ritativ multe ltele)
In folderul FS\TPA\PRESET\SYSTEM\MENU exista menu.ml (hai un backup pe calculator, deoarece daca pune acest fisier la loc se revine la meniu original)
aici se adauga diferite teme (meniu personalizate, facute de alti)
Voi posta un link catre pagina mea unde se vor gasi multe teme(meniuri customizate) dar momentan lucrez la ea dar pun niste imagini
http://img110.imageshack.us/img110/6625/menu21sj.jpg
http://img381.imageshack.us/my.php?image=image408qm.png
http://img151.imageshack.us/img151/2264/preview1io.gif
http://img141.imageshack.us/img141/1268/preview1pp.gif
Asta il am eu pe k750i>w800i al meu imi place deoarece lucrz pe mac la servici.
http://img301.imageshack.us/img301/3567/preview26am.gif
++ multe altele (can imi voi termina pagina|cat de curand| voi posta toate temele care le am)
Fanatique
692 mesaje
din 08/10/2005
04 iulie 2006, 23:30:26
"Detected SonyEricsson: K750/D750.
Flash Loader not accepted! Try to Recover phone before flashing."
Are CID 49? :(
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 23:33:03 • actualizat 04 iulie 2006, 23:38:11 (4 ori)
RESKIN media playeru (k750i) si WalKmanu (w800i)
(Tot la mien pe pajina o sa le pun pe toate culese pana acuma si cateva facute de mine) Momentan doar ceva monstre
K750i
http://img119.imageshack.us/img119/3740/k750i5bc.png
w800i
http://img119.imageshack.us/img119/9997/w800i7si.png
si multe altele.....
GonZo
147 mesaje
din 30/04/2006
04 iulie 2006, 23:49:17
Fanatique 04-07-2006 23:30:26
Are CID 49? :(
cu ce ai incercat sa citesti cidul? cu davinci 13.7?
uite incearca cu asta:e 13.8 ar trebui sa recunoasca si cele cu CID 49 (dar daca ai CID 49 nu poti sa faci nimica cu FAR MANAGER :( telefoanel luate la oferta orange toate au cid 49 dupa cum am inteles :( )
http://www.yourfilehost.com/media.php?cat=other&file=client138.rar
Diu
4446 mesaje
din 04/09/2005
05 iulie 2006, 00:46:47
Valabil la toate Se? M-ar interesa la k508i.
GonZo
147 mesaje
din 30/04/2006
05 iulie 2006, 08:49:59
yo 05-07-2006 00:46:47
pai nu situ exact da poti afla  :D incerca sa te conectezi cu far manager la tel ca si in tutorialu de mai sus daca vei ce ii in folderul FS aunci merge  :D
GonZo
147 mesaje
din 30/04/2006
11 iulie 2006, 11:55:50
http://gonzo.uv.ro/se/meniu/meniu.php aici meniuri urmeaza ca sa pun si gidu acolo si sa fac si restu  :D
Înapoi la Tuning
Inițiator acum 14 ani
GonZo
Ultimul acum 9 ani
alex2nut
0.023⋅4⋅6
